Total pressure at inlet
Old   July 5, 2019, 03:31
Default Total pressure at inlet
Julian121 is on a distinguished road
I am doing a simulation of an axial flow compressor by CFX.
I have a set of experimental data to validate the solution.
The ambient pressure has been measured by a barometer, but the pressure at the inlet is not known. It is assumed that the pressure at inlet is equal to the ambient pressure, though.
Is it reasonable to assume this pressure as total pressure at inlet while there exists a velocity at inlet and there is no velocity in ambient?
Shouldn’t they be different in general?
Julian121 is offline   Reply With Quote
Old   July 5, 2019, 09:12
If the stagnation pressure at your inlet is the ambient pressure - that is, there are no significant losses between the stationary atmosphere and your inlet - then the total pressure inlet with ambient pressure is the correct choice.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Old   July 6, 2019, 06:14
sheaker's Avatar
Oskar
sheaker is on a distinguished road
Hello.
In my opinion it is not best idea to use pressure at both - inlet and outlet boundaries. I think that the better choice would be to combine mass flow and pressure BC's.
I was doing axial turbine simulation in CFX for my master thesis and I was using mass flow at inlet BC and static pressure at outlet BC. In Your case I would try total pressure at inlet and mass flow at outlet.
If there are parts of inlet that are not included in Your geometry (e.g inlet bell mouth) You should calculate/estimate total pressure drop in between ambient and Your inlet BC. Sometimes they can not be neglected.
Best regards,
Oskar
sheaker is offline   Reply With Quote
Old   July 6, 2019, 08:08
Originally Posted by sheaker View Post
Hello.
Would there be any total pressure drop between ambient and inlet?
Old   July 6, 2019, 08:26
There are always losses. A sharp edged entry will have quite a bit of losses, a bell-mouth opening will have very small losses. But there will always be some loss.
Whether that loss is significant depends on what you are modelling and how accurate you need to be.
Reversed flow using pressure inlet and outlet? here_for_help FLUENT 0 September 28, 2018 16:20
Getting divergence while increasing the back pressure at pressure outlet greenfields15 FLUENT 0 March 19, 2018 00:39
Pressure Inlet Boundary Condition Issue zoeburton1987 FLUENT 0 May 15, 2012 10:20
Boundary Conditions : Total Pressure or Velocity Gearb0x OpenFOAM Running, Solving & CFD 2 February 28, 2011 22:18
Total pressure and velocity inlet BC ff FLUENT 1 May 28, 2003 22:24
