error:zero divided appears after mesh copy in CFX-pre
Old   July 4, 2019, 22:56
Smile error:zero divided appears after mesh copy in CFX-pre
Yuchen Ma
MaYC is on a distinguished road
Hello, I am doing a steady simulation of compressor blade. I build the domain with 2 IGV and 1 blade. I want to simulate 2 passages which include 4 IGV and 2 blades. I use the copy mesh command in CFX-pre and define all newly appeared surface in correct boundary setting. When I start the simulation. It always crashes in the beginning of simulation, showing error: zero divided. I check the setting in the CFX-pre,all seems ok. And the single passage simulation works well. I do not know what I did wrong in the process. Could anyone shear their experience on this issue?
MaYC is offline   Reply With Quote
Old   July 5, 2019, 09:17
First read the FAQ on this: https://www.cfd-online.com/Wiki/Ansy...do_about_it.3F
Check that your second mesh region is properly connected to the first and there are no gaps or slivers.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
mesh copy+ zero divided
Mesh Transformation in CFX PRE AS_Aero CFX 6 August 23, 2018 20:09
Gambit problems Althea FLUENT 22 January 4, 2017 04:19
Mesh from finished FSI to CFX Pre? Luk_Fiz CFX 2 December 2, 2013 03:54
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 04:52
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 19:10
