body operations
Old   November 29, 2005, 09:24
Default body operations
fintan
i'm a final year mechanical engineering student modelling exhaust fume dispersion for my final year project. i successfully modelled a car in workbench and want to run a simulation to model the dispersion of exhaust fumes of a car in an air tunnel setup. i'm told that to save trouble and complications, draw a model of a solid block for the air tunnel and cut the volume of the car from that block but i just can't find a way to do this. i'm sure its a simple operation but for some reason i can't do it! any suggestions??
i went ahead and used the model of the car in a frozen block and the only problem is that the face of the exhaust that i set as an inlet into the air tunnel is confusing the computer. the 2-Dsurface is being treated as a volume and when set as an inlet, the arrows point toward the face from both sides of the surface.
Old   November 30, 2005, 03:09
Default Re: body operations
DAK565656
It's easy. Create->Body Operations->cut material
Old   November 30, 2005, 23:56
rajit
if you are freezing the car then rather try freezing the huge block and then perform the body operation as said by mr.Dak. it is really simple.
thanx
Old   December 1, 2005, 00:05
rajit
iam sorry iwas wron the last time around.the cache is the cutting tool shud be frozen.in your case the cutting tool is the car.
one more tip regarding this if there are any rounds in the surface you are talking abt consider removing them and then try the operation.
How to make appear edge/line body (created in design modeler) in the meshing tool Rockda ANSYS Meshing & Geometry 6 June 9, 2016 00:10
6DOF with floating body bounce back. paka FLUENT 4 June 6, 2013 12:32
Imported ICEM mesh has additional body in the mesh Procyon CFX 1 January 27, 2011 17:21
Body in windtunnel - high preassure behind the body? Andyjoe OpenFOAM 4 February 16, 2010 11:57
Body force at the cell face Souviktor Fluent UDF and Scheme Programming 0 March 31, 2009 09:54
