View Factors
Old   June 26, 2019, 06:50
Default View Factors
ferbf is on a distinguished road
Hi everybody,
I'm new in ANSYS CFX, so sorry if I don't express my ideas properly.
Could someone tell me how to calculate view factors in CFX?
I have read in other posts that ANSYS CFX don't use view factors for calculations (shape factor), but i think that it is possible to calculate this factors using Monte Carlo method, but i don't know how.
Thanks in advance.
ferbf is offline   Reply With Quote
Old   June 26, 2019, 07:55
The Monte Carlo method does not calculate view factor as it works our radiative transfer by the Monte Carlo method (obviously), which does ray tracing on each photon path so does not need a view factor. Instead it requires lots of rays to be traced so that the sum total approximates the view factor.
The method which comes closest to using a view factor is the Discrete transfer model. Investigate this model to see if you can get view factor out of it.
It has been a while since I did radiation modelling but I think that is correct
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Old   June 26, 2019, 08:48
Thank you, ghorrocks.
Do you know where could I do it? I've been trying to find it in "Variable Selector" in CFD-Post, but it isn't there.
Old   June 26, 2019, 10:24
Opaque will become famous soon enough
Perhaps going back to the definition of view factor will help to figure out the approach
View Factor is the ratio between the energy leaving a surface, and the amount arriving at another by any possible means.
If you are interested in a specific view factor between surface A, and surface B. You can setup a problem with all boundaries being blackbodies, i.e. Emissivity of 1, all boundaries temperatures set to 0 [K], and set the temperature of A to whatever you want, say 1000 [K].
You now deactivate all the models but radiation, and solve the problem. The view factor between A and any of the other surfaces is the ratio
areaInt(Wall Irradiation Flux)@SurfaceOfInterest / Total Emission atSurface A
It is a costly process if you want the ratio between other surfaces.
Good luck
Opaque is offline   Reply With Quote
Old   June 26, 2019, 10:45
Thank you Opaque for your answer.
I will try using this method, which seems to be reasonable and intelligent.
Thank both you for your help
factor, monte carlo, view, view factor model, view factors
Accessing View factors of a patch for postprocessing pss47 OpenFOAM Post-Processing 5 June 8, 2020 11:53
Where to find the view factors in .sol file? RuthMcNabb22 Main CFD Forum 0 July 24, 2018 13:53
HELP!!! viewFactorsGen is not calculating view factors!! zfaraday OpenFOAM Pre-Processing 0 September 15, 2014 09:55
Radiation With View Factors in OPENFOAM MadiS OpenFOAM 1 August 23, 2012 12:21
View factors calculation outside Fluent Sambou FLUENT 1 January 21, 2006 14:48
