icem block question
Old   November 17, 2005, 06:41
Default icem block question
smart
can anyone tell me the difference between 2D surface blocking and 2D planar, can 2D surface blocking be convert to 3D block(translate, rotate)? thanks!
Old   November 18, 2005, 10:17
Default Re: icem block question
Myron
2D surface blocking will try to create a blocking for each surface of the model. So it could be 3D overall - but the blocking will only be faces - no internal blocks.
2D Planar will put a single planar block at the middle X-Y plane of the geometry.
Any blocking can be tranformed as you desire. Blocking > Transform.
Old   November 22, 2005, 07:13
smart
thank you Myron!
ICEM --- question about repair geometry zhaohui ANSYS Meshing & Geometry 1 April 21, 2010 19:54
ICEM block mesh with a ball in a cylinder tube Li CFX 6 August 11, 2008 06:44
Delete block edges in ICEM CFD YK CFX 1 June 22, 2008 15:30
Icem question: convert prisms to hexahedrals Nico CFX 0 May 28, 2007 13:45
what is orient block in icem suresh CFX 0 April 13, 2007 11:33
