June 17, 2019, 07:56 |
pump FSI
Yining CHEN
Rep Power: 8 |
Hello!
I am new about FSI simulation. I simulate a periodic domain of the pump's rotor and stator from a 3D CAD file. The procedure is... 3D cad file -> create periodic and fluid domain -> import ansys geometry -> export to turbogrid(to create mesh) -> setup CFX-Pre -> RESULT Is it possible to do the FSI simulation by this cfx result? or I need to import origin cad file into ansys to do the FSI? Thnak you~ |
June 19, 2019, 02:26 |
Jiri
Rep Power: 13 |
it depends if you are talking about 1way or 2way FSI. 1way: just export the results (e.g. pressure) from CFX and apply on the pump structure. 2way: import CAD file into CFX Pre, define FSI and you can initialize the results from your previous analysis. 2way FSI is a very complex analysis, you may encounter many issues and the result may not worth it. |
June 20, 2019, 01:10 |
Yining CHEN
Rep Power: 8 |
Thank you so much!
I found some tutorial videos on Youtube about 1way of FSI. It seems that 1way is easier than 2way! Thanks for your reply! |
June 20, 2019, 12:34 |
Jiri
Rep Power: 13 |
1 way is much more easier, in 2 way FSI you would come across many difficulties. SInce you do not have years of experience in CFX I would not recommend 2 way FSI. Go for 1 way.
fsi 2-way coupling, fsi problem, pump, turbo machinery |
CFD of a small end suction pump on solid works | kliff | FloEFD, FloWorks & FloTHERM | 0 | June 13, 2017 19:44 |
centrifugal pump | Chalghoum | CFX | 18 | April 16, 2014 07:37 |
Assistance in Vacuum pump simulation | enr_venkat | CFX | 5 | November 20, 2012 12:50 |
Regenerative pump modelled in FLOEFD pro | YYY | FloEFD, FloWorks & FloTHERM | 2 | October 5, 2009 06:04 |
how to extend FSI 2D codes to 3D, need advises | abouziar | Main CFD Forum | 1 | May 30, 2008 05:08 |
