The ANSYS CFX partitioner exited with return code 1
Old   June 16, 2019, 20:06
Default The ANSYS CFX partitioner exited with return code 1
Alex
cfxgu is on a distinguished road
hi Guys, i have this probem: i am trying to simulate the confluence of 2 streams. But the cfx-solver can't work correctly. Could someone help me with this errors:?
| Topology simplification is activated with the following |
| restrictions: |
| - Mesh regions referenced only within User Fortran and NOT |
| in the command file will cause the solver to stop. |
| - The solver will stop during any "Edit Run in Progress" step |
| if new 2D regions are referenced. |
| ERROR #001100279 has occurred in subroutine ErrAction. |
| Message: |
| The intersection algorithm runs out of memory. This can be caused |
| by insufficient INTEGER and/or REAL memory. Please run again wit- |
| h increased memory settings. |
| Message: |
| Stopped in routine ILOCCS |
| An error has occurred in cfx5solve: |
| The ANSYS CFX partitioner exited with return code 1. |
| The following user files have been saved in the directory |
| //vstor2/pcpool/j5ra0046/Desktop/Masterarbeit/Numerische |
| Simulation/HQ100_pending/dp0_CFX_1_Solution_1/CFX_001: |
| trace |
| For CFX runs launched from Workbench, the final locations of |
| directories and files generated may differ from those shown. |
| Warning! |
| After waiting for 60 seconds, 1 solver manager process(es) appear |
| not to have noticed that this run has ended. You may get errors |
| removing some files if they are still open in the solver manager. |
This run of the ANSYS CFX Solver has finished.
cfxgu is offline   Reply With Quote
Old   June 17, 2019, 01:24
Focus on the first error. Most of the rest of the errors are caused by the first one anyway.
It is saying the integer intersection memory is exhausted. So change the stack sizes as it saying that is what you need to do.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Old   June 17, 2019, 01:44
flotus1's Avatar
Alex
flotus1 has a spectacular aura aboutflotus1 has a spectacular aura about
Edit: Glenn was faster...
flotus1 is offline   Reply With Quote
No matching function error: Phase change source term added to interMixingFoam wavefunction OpenFOAM Programming & Development 2 February 4, 2022 08:46
FSI simulation in ansys cfx Arash67.m CFX 1 September 29, 2017 10:52
ANSYS CFX solver exited with return code 2 vmlxb6 CFX 6 June 22, 2017 19:01
Ansys SIG$ILL error loth ANSYS 3 December 24, 2015 06:31
Missing math.h header Travis FLUENT 4 January 15, 2009 12:48
