*** Run-time memory configuration error ***
Old   November 11, 2005, 15:06
Default *** Run-time memory configuration error ***
M. Sartori
how do I do to solve this error? ------------------------------------------------------------ ERROR #001100279 has occurred in subroutine ErrAction. Message:
*** Run-time memory configuration error *** Not enough free memory is currently available on the system. Could not allocate requested memory - exiting! ----------------------------------------------------------- My computer has 3 Gb of RAM and CFX informs that it will use 2Gb.
Regards
Old   November 11, 2005, 18:39
Default Re: *** Run-time memory configuration error ***
Stevie Wonder
It looks like you've reached the OS limits. I think the OS can only allocate the maximum of 2Gb of RAM for a process (single job). Why don't you try to run in parallel?
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 16:33
error while running paraFoam! padmanathan OpenFOAM 9 October 13, 2009 06:17
[Netgen] Installation of Netgen in SuSE Linux 92 edvardsenpriv OpenFOAM Meshing & Mesh Conversion 23 January 16, 2009 07:12
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 03:58
