flow massflow
Old   November 11, 2005, 03:07
Default flow massflow
Anke Hentschel
This is Anke from Germany. At the moment I try to simulate the force on valve between two pressure chambers. These two chambers are connected with a short pipe. In the high pressure chamber is a valve. This valve looks more or less like a thin beam. Up to now the simulation model works very well. At the moment I try to do a simulation with a small mass flow. My problem is that, if I work with a very small mass flow (0,004kg/s) and with a little pressure difference (0,03bar) between these two chambers, I assumed to have a very small force on the valve. But something went wrong. If I have zero mass flow, I still have a force one the valve and this is impossible. I had discussions with my colleagues I contacted a university professor, but nobody could answer my question. I guess it could be a problem with numerical solver algorithm, because of the small mass flow, but I am not sure. So I would be very happy if you can tell me what the problem is and maybe what's the solution for my problem.
CU Anke
Flow meter Design CD adapco Group Marketing Siemens 3 June 21, 2011 09:33
What is the difference between liquid reactive flow and gas reactive flow? James Main CFD Forum 6 May 15, 2009 13:14
reversed flow at velocity inlet / mass flow inlet ib FLUENT 1 March 26, 2007 14:11
How to change from mass flow to volume flow rate stanley FLUENT 1 February 2, 2007 07:44
potential flow vs. Euler flow curious ... Main CFD Forum 23 July 21, 2006 08:40
