CFX definitions of Rotating Variables: Confusing!
Old   November 8, 2005, 02:24
Default CFX definitions of Rotating Variables: Confusing!
Prakash
In CFX documentation, it is mentioned that p(stat) is "relative" static pressure. Why is it relative? As far I know, we have only one static pressure.
I am working on rotating domains. Bit confused with various parameters, hoping anyoine can clarify!
Where does one use variables like Rotating frame total temperature, rotating frame total pressure etc ? Are these the Total Pressure and Total Temperature which we see in the variable list in POST.
As far as I know, we use relative values only like relative frame total temperature, relative frame total pressure.etc.
Again, if I get back to static pressure, it is said in documentation that "Pressure" defined in CFX is the modified pressure for k-e model. If I use SST model, then how does the definition of "Pressure" change and what is Absolute pressure then?
Thanks
Prakash
[ICEM] Proper way to name boundaries on 2D model for use in CFX? RossFS ANSYS Meshing & Geometry 4 November 10, 2011 03:38
Pros and Cons for CFX, CFdesign, COMSOL Val Main CFD Forum 3 June 10, 2011 03:20
CFX: How to save variables of boundary domain of transient run and use it as input papanef CFX 5 November 10, 2010 17:31
Global variables storage in CFX. Fabio Kasper CFX 1 October 6, 2000 09:21
Saving variables on a user patch with physical coordinates Zoltan Turzo CFX 2 April 20, 2000 16:05
