Should I use Particle Transport Modeling for high gas volume fraction two-phase flow? |
June 5, 2019, 05:34 |
Terry
Rep Power: 8 |
Hi friends!
I am learning CFX and there are some basic problems that confuse me. I'm going to simulate gas-liquid two phase flow whose gas volume fraction is very high. Like annular flow. The volume fraction of gas ranges from 90% to 99%. Which model should I choose? Eulerian-Eulerian or Lagrangian Particle Tracking? After reading the model guide, maybe Particle Transport Modeling is appropriate? i.e. Treat the liquid phase as dropltes? I am going to observe the velocity profile of two phase after two phase mixture flow through a vane type swirler. The structure of it like the picture I attached. Could someone help me, thanks Last edited by TerryNiu; June 5, 2019 at 07:48. |
June 5, 2019, 06:36 |
Gert-Jan
Rep Power: 28 |
If the liquid volume fraction is 1%, then LPT is the way to go. But if you have annular flow with 10% liquid volume fraction, then Euler might be better.
It all depends on the question that you are trying to answer when modeling CFD. Can you tell us more? |
June 5, 2019, 07:43 |
#3 | |
Terry
Rep Power: 8 |
I am going to observe the velocity profile of two phase after two phase mixture flow through a vane type swirler. The structure of it like the picture I attached. |
June 5, 2019, 08:07 |
Gert-Jan
Rep Power: 28 |
Difficult problem. Main uncertainties are with the droplets hitting the wall. Will they stick, coalescence, break up, re-entrainment, rivulets, etc. And if they re-entrain, what wil lthe droplet size be.....??
Nevertheless, if you are only interested in the velocity profile, then you could opt for LPT. If you are interested in where the liquid ends up, then Euler might be better. Maybe it is even better to use a model that can handle both at the same time. Then mass can go from LPT to Eu, vice versa. These are available in fluent or Star-CCM+. Not in CFX. |
June 5, 2019, 08:40 |
#5 | |
Terry
Rep Power: 8 |
Setting the height of the stream in the free channel | kevinmccartin | CFX | 12 | October 13, 2022 22:43 |
Fluent Limitations | tymcme | FLUENT | 6 | August 1, 2022 09:50 |
Domain Reference Pressure and mass flow inlet boundary | AdidaKK | CFX | 75 | August 20, 2018 06:37 |
Is it possible that multi-phase flow shows gradation of volume fraction? | kjh9537 | Fluent UDF and Scheme Programming | 0 | June 23, 2017 15:16 |
Stuck in a Rut- interDyMFoam! | xoitx | OpenFOAM Running, Solving & CFD | 14 | March 25, 2016 08:09 |
