Error when I use Fortran Routines in parallel mode
Old   June 3, 2019, 10:31
Default Error when I use Fortran Routines in parallel mode
Joăo de Sousa Bomfim Neto
Joao Bomfim is on a distinguished road
Hí guys,
I have a problem when I use routines in FORTRAN in parallel mode. In serial mode there are no problems, but in parallel the error with code 30 appears. I put a copy of the cfx5mkext.ccl file with the correct architecture and the solver-mpi.lib line in the working directory and there is still the problem. Has anyone had this and solved it? I'm probably making a mistake in handling the cfx5mkext.ccl file. Thank you very much.
Joao Bomfim is offline   Reply With Quote
cfx, fortran, parallel
Running Error using Compressible OpenFoam Parallel mode dhendria OpenFOAM Running, Solving & CFD 0 February 13, 2014 21:53
parallel Grief: BoundaryFields ok in single CPU but NOT in Parallel JR22 OpenFOAM Running, Solving & CFD 2 April 19, 2013 17:49
Comparison between C/C++ and Fortran? rick Main CFD Forum 45 September 6, 2011 01:52
User fortran routines, DEBUG AND OUTPUT Bloshchitsyn Vladimir CFX 5 October 29, 2007 02:31
TASCflow,problem with script and parallel mode Zbynek Hrncir CFX 0 October 2, 2001 08:30
