May 24, 2019, 08:45 |
transient residual unable to reach 1e-4
Greg Hwang
Rep Power: 7 |
Hey guys! I am a newcomer to CFX.
Recently I was working on the transient simulation of a rotating seal model with tip leakage(the tip clearance is set to 0.5 mm, 2% height of the blade). I found that it is unable for the transient simulation to reach the prospectively residual (1e-4 or 1e-5, which is required by many papers I read ) since the steady simulation reached well. I tried to change the number of elements from 6.8 million to 70 million, however all the RMS Mom remained between 1e-3 and 1e-4. Then I got rid of the tip clearance in that model, the transient residual could reach below 1e-5 well. Hence, I infer that the small tip clearance might be the very cause of bad residual in transient simulation. Nevertheless the small tip clearance is the focus point of my research, I cannot just get rid of the clearance. I would appreciate it if anyone could help 1. Is my inference rational? 2. How can I improve the residual for the transient simulation of rotating seal model with small tip clearance? For your information: [Time duration]:total time 0.5s [Time step]:1e-4\5e-5\1e-5 were tried [Coeff loops]:3 to 5 [Turbulence]:SST |
May 25, 2019, 19:08 |
Rep Power: 144 |
Your question is a FAQ: https://www.cfd-online.com/Wiki/Ansy...gence_criteria
It is normal for a finer mesh to be less stable than a coarser mesh. It as less numerical dissipation, so is less able to damp the motions.
May 27, 2019, 02:29 |
M
Rep Power: 12 |
To be completely sure about the residuals you can let cfx write out the residual magnitudes in the domain. Then in CFD-post you can define a point location or whatever and plot the residuals.
(Point location allows you to find the maximum value instantly) This will give you certainty about the location. |
May 27, 2019, 08:43 |
Greg Hwang
Rep Power: 7 |
Thanks a lot for your reply and I will check FAQ later.
Actually what you talked about that finer mesh shall be less stable than coarser mesh is really contrary to my common sense. However when I use same case by only changing turbulence to k-epsilon or RNG k-epsilong, the residual could reach even 1e-6. What I am confused about is why just SST turbulence work so bad. Thanks again, and wish you a good day. |
May 27, 2019, 08:54 |
Greg Hwang
Rep Power: 7 |
Hey, thanks for your reply.
Actually I am not clear what you suggested me to do. The residual problem I asked happened in the process of solving, and the residual was updated with each timestep. Hence I am confused that how finding the maximum value in the CFD-post could help me improve the residual reaching 1e-4 or better? Please enlighten me with your instructions if I missed anything. Thanks again. |
May 28, 2019, 06:13 |
#6 | ||
Rep Power: 144 |
Finer meshes have less numerical dissipation due to reduced truncation error, and reduced dissipation means reduced numerical stability which means harder to converge. A bit of knowledge of how CFD works trumps somebody's "common sense" guesswork. Quote:
And to answer your original question - please read the FAQ I linked to. I have answered this question thousands of times and I got sick of writing it over and over so wrote an FAQ on it. Please read the FAQ, it really does discuss the important issues.
cfx |
pimpleDyMFoam computation randomly stops | babapeti | OpenFOAM Running, Solving & CFD | 5 | January 24, 2018 05:28 |
pressure in incompressible solvers e.g. simpleFoam | chrizzl | OpenFOAM Running, Solving & CFD | 13 | March 28, 2017 05:49 |
Micro Scale Pore, icoFoam | gooya_kabir | OpenFOAM Running, Solving & CFD | 2 | November 2, 2013 13:58 |
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 | bookie56 | OpenFOAM Installation | 8 | August 13, 2011 04:03 |
Error while running rhoPisoFoam.. | nileshjrane | OpenFOAM Running, Solving & CFD | 8 | August 26, 2010 12:50 |
