How to put flux values in CFX in differential form |
May 23, 2019, 08:40 |
Abdullah Arslan
Rep Power: 7 |
Hi all,
To apply a boundary condition for methane steam reforming the expression is (dT/dy)i=R*delHi/lambda. T is temperature, y is height, R is reaction rate, delH is enthalpy of formation, and lambda is thermal conductivity. It is a surface reaction. Because reaction may have many species besides CO and H2 like CO2, H2O etc so dT/dy needed to be calculated for each specie (dT/dy)i. Where 'i' can be CO, H2 etc my question is how to assign a single wall all these temperature boundary condition for each specie? Even if it is summed and apply as a single quantity 'dT/dy=Sum(R*delHi)/lambda', then how to assign this function to the wall which is parallel to flow (x direction) whereas function is dependent on 'y' coordinate. P.S i said so because, units are in K/m so we cannot multiply it with length of wall (L) to have units in K. |
June 6, 2019, 12:22 |
Abdullah Arslan
Rep Power: 7 |
In simple term, if dT/dy =200 K/m on a wall that is parallel to x'axis. (normal boundary condition to wall)
June 6, 2019, 12:55 |
Gert-Jan
Rep Power: 27 |
I really have no idea what you are trying to do.
There is only one temperature. So there is only one dT/dy at the wall. Not 10. You are looking for R(CO), R(H2O), R(H2) which then have to be something like: Ri = di/dt = ai*delHi/lambda/(dT/dy).with ai a certain constant of species i. |
June 6, 2019, 15:26 |
#4 | |
Abdullah Arslan
Rep Power: 7 |
Actually, I think dT/dy is temperature gradient between j-1 and j node or like plug flow reactor at entire length of y at each section. But I think is temperature gradient, (between j-1 and j) so I just need to calculate it at that node and multiply it by x (0 to i). Like single integral, but with x as variable (though it doesn't make any sense) |
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 07:30 |
Udf for moving heat flux in 2D cylindrical geometry | devia21 | Fluent UDF and Scheme Programming | 0 | April 20, 2015 00:27 |
Question about FDM and supersonic flows | Guillaume_Fournier | Main CFD Forum | 2 | January 20, 2013 22:41 |
ATTENTION! Reliability problems in CFX 5.7 | Joseph | CFX | 14 | April 20, 2010 15:45 |
Radiation/Heat Flux in CFX Post | Soren | CFX | 1 | July 2, 2002 12:55 |
