Question about stage interface method between unequal interface heights.
Old   May 20, 2019, 05:09
Default Question about stage interface method between unequal interface heights.
Young Seok Kang
electra0614 is on a distinguished road
Hi everyone,
I'm trying to calculate a centrifugal compressor stage including impeller and diffuser rows with CFX.
One problem I'm sufferuing now is that the impeller exit blade height and diffuser inlet blade height are different. (Flow path is not continuous. Please refer to the attached image)
I used stage (mixing plane) method to interface between the impeller and the diffuser.
But I found out that this causes mass flow rate difference between these two domains. (Higher mass flow rate in the diffuser domain)
I found a similar thread regarding this problem, however, found out no clear solution. (Interface between a stator-rotor with sudden change in flowpath of the turbine)
Any advice for this problem?
Many thanks in advance.
electra0614 is offline   Reply With Quote
cfx, stage
Basic Nozzle-Expander Design karmavatar CFX 20 March 20, 2016 09:44
How to apply heat flux at the interface when using VOF method? princekar FLUENT 0 November 15, 2015 08:47
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 07:20
smoothed interface capturing method: compressible. jinwon Main CFD Forum 0 May 14, 2007 01:20
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 21:09
