May 17, 2019, 08:14 |
Insert particle tracking
Dshing Sung
I simulated a nozzle with two phases of gas. The mixing of one gas into the other behind the nozzle works quite well. Now I would like to insert an area inside the nozzle where solid particles are injected. From there I would like to follow the particles and ideally also judge the deposition on the walls. Here I do not come at all clear. The help of Ansys isn't much help for me either. I have now added a subdomain to define the absorption. The next step is the "Particle Injection Regions". Here the help says what I can and must do, but not how. So first a very simple question: How can I insert these Particle Injection Regions? Is that an inlet? |
May 17, 2019, 11:40 |
Gert-Jan
Rep Power: 28 |
May 20, 2019, 04:57 |
Thanks
Dshing Sung
Thank you so much. Unfortunately I still use Ansys 18.2 and cannot change. Too bad, but maybe in a few years ^^
dispersion model with lagragian particle tracking model for incompressible flows | eelcovv | OpenFOAM Running, Solving & CFD | 54 | April 10, 2018 10:36 |
Particle tracking error | alchem | OpenFOAM Bugs | 5 | May 6, 2017 17:30 |
Ubuntu 12.10 + openfoam2.2.0 ==> paraview error message | peteryuan | OpenFOAM Installation | 6 | August 18, 2013 19:00 |
[OpenFOAM] ParaView ErrOr | soheil nazmdeh | ParaView | 1 | August 17, 2013 08:40 |
injection problem | Mark New | FLUENT | 0 | August 4, 2013 02:30 |
