Add a lag correction equation
Old   May 16, 2019, 11:49
Default Add a lag correction equation
Zhiyuan Liu
Saeef is on a distinguished road
It has been resolved
Saeef is offline   Reply With Quote
Old   May 16, 2019, 19:23
If you included some details of what you are modelling and how you modelled it we might be able to help you.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Old   May 16, 2019, 22:32
Smile
Zhiyuan Liu
It's a correlation for non equilibrium turbulent flows proposed by Olsen(2001).
Olsen, M., & Coakley, T. (2001). The lag model, a turbulence model for non equilibrium flows. In 15th AIAA Computational Fluid Dynamics Conference (p. 2564).
Old   May 17, 2019, 05:17
Gert-Jan
Gert-Jan will become famous soon enough
Don't know anything about your model, application or whatsoever. So, it is difficult to help, as Glenn already mentioned.
However in your KVN equation, you are dividing by a variable which can become zero. This is a source of troubles. Therefore, please make sure that this cannot occur by using min, max, abs or other numerical operators.
Gert-Jan is offline   Reply With Quote
Old   May 22, 2019, 11:58
Opaque will become famous soon enough
A bit more information on your model will help you obtaining suggestions.
So far, you have shown the equation you intend to solve and that you have not been able to converge the solution; however, no details on how you set it up in ANSYS CFX.
Opaque is offline   Reply With Quote
Old   May 23, 2019, 03:47
Zhiyuan Liu
There's no difference with normal simulations, only a lag of eddy viscosity needs adding. The lag equation was added by the CFX additional variable method, which was illustrated in the PDF file.
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 07:27
How to add Exner equation in settlingFoam jimbean OpenFOAM Running, Solving & CFD 1 October 6, 2013 10:59
add source term to transport equation m003020002 Fluent UDF and Scheme Programming 0 September 10, 2013 04:09
How can I add an equation of state for rho and cp ?? Canesin OpenFOAM Programming & Development 0 May 14, 2010 18:52
BCs for Pressure Correction Equation (SIMPLE) Bharath Somayaji Main CFD Forum 1 March 1, 2006 07:12
