Mesh: Import to CFX
Old   October 26, 2005, 03:14
Default Mesh: Import to CFX
DAK565656
I have no idea how to save mesh created in ICEM for CFX. I looked through tutorials. It is said to select OUTPUT tab and press button "output to cfx". The problem is that there is no such button in this tab
Old   October 26, 2005, 06:04
Default Re: Mesh: Import to CFX
houman
Hallo DAK56565656,
Which version of ICEM are you working with? (example: ANSYS ICEM CFD 5.0(CFX/CFD))...
regards, houman
Old   October 26, 2005, 06:28
DAK565656
ICEM CFD 10
Old   October 26, 2005, 07:27
Ram
In CFX-10 you will find 4 sub tabs Under Output to export mesh to CFX,CFX-4,Tascflow and Ansys. If you donīt find it could be installation problem.
Old   October 26, 2005, 07:40
DAK565656
You meant in ICEM 10? There are following buttons: 1) select solver 2) boundary conditions 3) write input 4) edit parameters
Old   October 26, 2005, 08:56
longbow
First, you need to "select solver". Then "write input" file for CFX-Pre.
Old   October 26, 2005, 10:22
Myron
In version 10.0 - look for Output > Select Solver > Ansys CFX. Once in CFX-Pre - Import Mesh and specify ICEM CFD as the format.
Old   November 19, 2005, 20:42
Nepal
I am sure you are into the ICEMCFD_CFD mode instead of ICEMCFD_CFX mode. You can get into ICEMCFD_CFX by add a argument <font color=blue>-cfx</font> after your command.
Gambit problems Althea FLUENT 22 January 4, 2017 04:19
Error about import mesh from CFD to CFX Stephen CFX 8 June 27, 2011 10:02
Import cfx mesh into fluent Michele CFX 0 March 22, 2006 09:43
hex mesh using cfx mesh. mehul CFX 0 October 31, 2005 08:01
importing mesh from ICEM CFD into CFX 5 Jay CFX 2 November 12, 2002 14:46
