Opening BC for multiphase problem
Old   October 25, 2005, 12:06
Default Opening BC for multiphase problem
John
Hi, all
Does someone have expeience of defining an opening BC for a gas-liquid phase problem? It seems that I need to input both gas liquid velocities. However I do not know that.
Please give some comments, Thanks!
Best regards!
John
Old   October 25, 2005, 12:22
Default Re: Opening BC for multiphase problem
Rui
Whether it's a multi-phase or a single-phase problem, on an Opening BC you may input the pressure instead of velocity.
Take a look at the Documentation, Solver Modelling - Boundary Condition Modelling - Opening, and Solver Theory - Basic Solver Capability Theory - Boundary Conditions - Opening
Regards,
Rui
Old   October 25, 2005, 12:37
John
Hi, Rui
Thanks for your reply.
Yes, I can choose to input pressure, however in that case I need to input volume fractions of gas and liquid as well. I also need to know the values of the additional variables at opening location, which I do not know.
Thanks!
John
Old   October 25, 2005, 13:46
Rui
The volume fractions and the additional variables values at the Opening BC will only be used for flow into the domain.
If in your Opening BC there is actually flow into the domain, you have to know the volume fractions and the additional variables values that are flowing into your domain.
But there's another option which isn't mentioned in the Documentation, and which you may only be set editing the .ccl file: BOUNDARY : out
Boundary Type = OPENING
Location = out
BOUNDARY CONDITIONS :
MASS AND MOMENTUM :
Option = <font color="red">Extrapolation</font>
END
END
END
However, this was told to me by the CFX support: "Note that this type of treatment of the b.c. should not be used for a steady state case, as it is not constrained enough"I never used this type of definition, so I don't know if it works well or not.
Regards,
Rui
Problem Importing Geometry ProE to CFX fatb0y CFX 3 January 14, 2012 20:42
Can I solve this problem by Fluent? Kai_kc FLUENT 1 October 27, 2010 06:29
problem opening case and data in fluent Adam FLUENT 1 February 15, 2007 17:53
Opening Andrew CFX 4 April 20, 2006 15:00
problem in opening CFX-pre and CFX-post 10.0 eka CFX 0 April 14, 2006 15:47
