May 14, 2019, 03:16 |
Restart CFX Analysis from last time step
Aashi
Rep Power: 7 |
Sir i am performing the sloshing simulation i calculated the time to complete the simulation which is 3 days but when it reaches 2.5 day my electric power suddenly went off then on after couple of minutes
Sir i want to know is it possible to restart the analysis from the last time step where the power shut down occur please help me |
May 14, 2019, 04:26 |
M
Rep Power: 13 |
This will be possible provided you created some full back-up files or results files while running. Then you can rerun using the -ini option when calling the solver.
https://www.sharcnet.ca/Software/Ans.../i1304960.html |
May 15, 2019, 08:50 |
restarting Cfx Analysis
Aashi
Rep Power: 7 |
thanks for your kind response can you please make it more clear in my situation when the analysis going on it also create the back up file folder but how to start from that back up as there is no option in cfx solver when i opened it as when i started it starts from beginning
please help me out |
May 15, 2019, 17:37 |
Erik
Rep Power: 23 |
Did you write and .full or .bak files? Did your transient results you were writing have all variables? What results do you have? Just choose one of these files for your initial conditions if you wrote any. If you didn't, then you are SOL, and will have to start from the beginning.
Just be sure to write backup files during transient simulations. |
May 18, 2019, 09:46 |
Run from back up file
Aashi
Rep Power: 7 |
thanks for you kind reply erik sir yes i have wrote the backup file but when it restart from that particular time step that is back up file it runs up to to simulation end time but when i check the results it only shows result from backup file lets say time step of back up is 120 it shows results from 120 onwards why is it so can any one here to help plz
cfx |
courant number increases to rather large values | 6863523 | OpenFOAM Running, Solving & CFD | 22 | July 6, 2023 00:48 |
Time Step Continuity Errors simpleFoam | Dorian1504 | OpenFOAM Running, Solving & CFD | 1 | October 9, 2022 10:23 |
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field | lakeat | OpenFOAM Community Contributions | 58 | December 23, 2021 03:36 |
Star cd es-ice solver error | ernarasimman | STAR-CD | 2 | September 12, 2014 01:01 |
mixerVesselAMI2D's mass is not balancing | sharonyue | OpenFOAM Running, Solving & CFD | 6 | June 10, 2013 10:34 |
