Probe options in CFX-Pre
Old   May 12, 2019, 06:09
Default Probe options in CFX-Pre
Julian121 is on a distinguished road
I have defined several probes in a rotor domain.
As the position update frequency, I have selected every timestep.
Domain name and frame type are unchecked.
Does this probe rotate with the rotor?
Is it in local or stationary frame?
Should I choose either domain name or frame type options?
Julian121 is offline   Reply With Quote
Old   May 12, 2019, 08:05
Why not just try it and find out? Hasn't it taken longer to write this post and wait for an answer compared to just running it and figuring it out?
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Old   May 21, 2019, 03:36
Does CFD-Post visualize the location of probe defined in CFX-Pre?
Probe function in CFD-Post allows to find the value at a new location not the one already defined.
I am not sure whether the probe I defined in rotor will rotate with rotor or it is in stationary or relative frame of refernce.
Old   May 21, 2019, 03:49
Probes are not carried through to CFD-Post. You could send a probe value to a CEL variable and then it would be carried through.
only 1 of many named selections not showing up in cfx pre mihirbhagat CFX 2 April 26, 2019 05:56
Alignment Problem in CFX Pre st7rocks Main CFD Forum 0 February 27, 2016 13:39
Is there a way to change settings in CFX pre file or play sessions on it without open Pierre1 CFX 4 March 13, 2015 16:38
CFX pre error in assigning material to the domains madan CFX 1 February 18, 2015 02:55
Under Relaxation Factors in CFX Pre akj Main CFD Forum 0 December 15, 2011 02:50
