batch mode in CFX
Old   October 22, 2005, 08:47
Default batch mode in CFX
mehul
Hi to all, I am workong on a silencer using cfx 10.I have to simulate four silencers,and all with some modifications.can any body tell me that how batch mode can be aplied t ocfx 10.i.e. i will apply different boundary conditions to one pre file (session file) and then run two or more solvers together.I think that i will have to make different def files and run toghether them,but how to run them is problem.i.e. i require some procedure or path.
Can any body help
Thanks in advance.
Old   October 22, 2005, 10:01
Default Re: batch mode in CFX
henpeckedman
Why do you want to run more than one solvers together? If you just want to apply different boundary conditions to one pre file. You can edit each case in the pre then output respective def file, or you can edit the ccl file. The cases can be run sequently, if I did not misunderstand your question. Anyway, if you want to run the solver in batch mode, please refer to the manual: ANSYS CFX-Solver Manager, Release 10.0 | Starting CFX-Solver from the Command Line.
Old   October 22, 2005, 11:15
mehul
ok thanks.My prob was to run simultaneously the prob,not together.It was my mistake to write. Thank u for ur guidance.
Old   October 25, 2005, 09:52
Michael Bo Hansen
http://www.cfd-online.com/Forum/cfx_...cgi?read=11475
Old   October 25, 2005, 10:00
mehul
Thanks very much Michael
Old   October 26, 2005, 08:19
Korsh Mik
Yes, in the command line I can run CFX in the batch.
But in Pre option - start solver in batch gives me a response: ======= An error has occurred in CFX5solve
writemms exited with non-zero return code 1 =======
Using Condor for batch queing with CFX ellevset CFX 3 June 16, 2016 13:09
fluent stops batch mode on error Ralf Schmidt FLUENT 1 March 1, 2008 11:35
Seek urgent help in batch mode Jack Martinez FLUENT 2 August 17, 2007 11:24
Meshing-only mode in CFX ? Nena CFX 0 August 10, 2007 06:03
Batch Mode (Urgent Help) Mahesh FLUENT 1 June 15, 2007 20:39
