May 7, 2019, 10:21 |
location of iso surface or iso clip
Aashi
Rep Power: 7 |
Hello to all Sir i am doing sloshing analysis in cfx after doing analysis i checked the results in cfd post i want to know the maximum slosh height for that i define the iso surface then iso clip to know the position of wave. now the problem which i am facing is that i defined the fluid ht to be 4.38[m] but the position of isoclip shows it to be 4.47[m] in cfd post why is it so, that the height of fluid became increased
please guide me why position of iso clip shows increased height |
May 7, 2019, 18:24 |
Rep Power: 144 |
I have no idea. Until you explain what you are doing and show some images of what you are getting we cannot help.
cfx |
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible | velan | OpenFOAM Meshing & Mesh Conversion | 3 | October 22, 2015 11:05 |
[General] interpolate and clip at a defined surface | WeTo | ParaView | 0 | May 23, 2015 08:55 |
ISO SURFACE | Umm.. | FLUENT | 1 | February 17, 2008 09:51 |
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug | unoder | OpenFOAM Installation | 11 | January 30, 2008 20:30 |
"stability" of turbulent jet surface location | Al | FLUENT | 0 | June 3, 2007 15:44 |
