CFX mesh interface between nozzle and blade
Old   May 6, 2019, 18:55
Default CFX mesh interface between nozzle and blade
Mahesh Chamarti
maheshchamarti is on a distinguished road
I am doing a steady state analysis of a radial turbo expander. I have created the meshes using turbogrid. There is a very minute radial gap between the two meshes. I am using the mixing plane mode for stage interface. I would like to know if this will affect my solution. Thank you.
maheshchamarti is offline   Reply With Quote
Old   May 7, 2019, 03:10
M
AtoHM is on a distinguished road
I'd rather rework my meshes to fit together instead of taking the risk of getting non-valid results, though CFX is able to handle small deviations.
If you set up your flow path correctly and consistently for both sides before meshing you'll get matching faces. But take the time and fix stuff like that right away. Later you might want to create some images and present those results to somebody, there will be questions about the gap and its influence instead of your actual results.
AtoHM is offline   Reply With Quote
Old   May 7, 2019, 18:53
Default Meshing issue
Mahesh Chamarti
Thank you for the Input. I tried a bunch of things but nothing seems to be working. I can email the mesh. Would be great anyone can inspect and propose a solution. Thank you.
Old   May 7, 2019, 19:22
If you could post some images of your mesh and the gap on the forum that would be better.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Old   May 8, 2019, 11:25
Mahesh Chamarti
Please find a snap shot of the mesh. The gap ism trying to show is the radial gap between the rotor mesh OD and vane mesh ID.
Old   May 8, 2019, 20:15
How wide is the gap?
Is it a gap or an overlap?
Old   May 8, 2019, 21:38
Mahesh Chamarti
The gap is of the order of 1 micron and at other places there is an overlap.
Old   May 9, 2019, 06:05
CFX can handle a small gap at the interface. I suspect your gap is going to be small enough that it is OK. But the only way to be sure is to run it and find out. If it is not working you will have sections which do not connect. This will be shown in the "non overlap ratio", and the flow vectors will treat it like a wall at the interface. It is quite obvious.
cfx, radial turbine, turbogrid
Basic Nozzle-Expander Design karmavatar CFX 20 March 20, 2016 09:44
CFX pre error in assigning material to the domains madan CFX 1 February 18, 2015 02:55
Errors with nozzle_rotor periodic repeat interface eromon84 FLUENT 2 August 17, 2013 14:24
Rotation of Blade in steam turbine ramu maddi CFX 0 September 10, 2008 06:15
Turbine nozzle blade coordinates tong Main CFD Forum 2 February 18, 2004 03:51
