rotating Domain, interpase problem
Old   October 20, 2005, 13:20
Default rotating Domain, interpase problem
carlos
Hi guys, I´m simulating the rotor of a wind-power-plant. My last simulations all terminated with errors, because there is coming a strong vortex in the whole body. This vortex is in the wrong direction of the normal wake-vortex by wind-power-plants. In the beginning of the Solver-run, the vortex is very small but after ten iterations he is rising very fast. It is a three-blade-rotor, so I´m simulating only 120 degrees in a rotating Domain.The symmetrie-planes are connected with an interphase (Periodic,rotational,GGI).The round Plane which connects the symmetrie-planes ist a free-slip-Wall. It seems as if the symmetrie Planes won´t work right, but I made a lot of simulations like this an they work. So if anybody can help I will be very greateful.
Old   October 20, 2005, 19:43
Default Re: rotating Domain, interpase problem
The problem is probably in your setup. Are you using periodic boundaries at the ends of the 120 degree segment? What are your entry and exit conditions?
Old   October 21, 2005, 05:25
Carlos
The two sidewalls with the 120 degree angle to each other are connected as Interphaseeriodic connection method: GGI periodicy: rotational
The entry is an inlet Frame type: stationary normal speed: 10 m/s
The exit is an outlet (I also tried opening) with relative pressure 0 Pa
Old   October 23, 2005, 19:17
What do you mean by "The round Plane which connects the symmetrie-planes ist a free-slip-Wall"? Do you mean the outer radius of the domain is a free-slip wall?
the rotating domain simulation lius Main CFD Forum 3 July 8, 2017 09:33
Domain Imbalance HMR CFX 5 October 10, 2016 06:57
Single Rotating Domain fluentnoob FLUENT 4 June 23, 2009 11:48
Counter rotating wall for rotating domain melvin CFX 0 February 4, 2008 05:51
Numerical solution to the rotating disk problem? johny Main CFD Forum 7 September 5, 2005 06:53
