Free surface flow with air entrainment
Old   October 14, 2005, 14:08
Default Free surface flow with air entrainment
Ken
Any hints to simulate using CFX free surface flow with air entrained into water and released at downstream? thanks.
Old   October 15, 2005, 16:49
Default Re: Free surface flow with air entrainment
Bak_Flow
Hi Ken,
the "normal" free surface model (homogeneous multiphase of VOF) is not the way to go for this problem. It assumes that the 2 fluids share the same velocity field (ie locked or homogeneous) therefore the entrainment and degassing will not be well predicted.
You will have to go to something like an algebraic slip or full Eulerian model. Here you still have to be careful as these models assume that all of the dispersed "phase" (although there can be more than one of them) has the same diameter which is used to calculate all of the exchange terms. In many cases it is not easy to come up with a representative diameter due to the break-up and coalescence processes...then you have to go to a more complex model! Something like MUSIG or population ballance!
Good Luck
Bak_Flow
Old   October 17, 2005, 11:56
Jon
Ken,
You can do this with the inhomogeneous free-surface model.
i.e. set two continuous phases, set the model to be free-surface, but do not set homogeneous.
This will use the free-surface model (giving a sharp interface), but solve for two seperate velocity fields.
Jon
Old   October 17, 2005, 15:59
Default Thanks.Re: Free surface flow
Ken
Thanks for all.
Jon, I tried that (free surface inhomo). but i really got confused with the drag coeff. I need a big Cd to initiate air entrainment from water surface, but I doubt the value is valid for air bubbles transporting in water. If I just simply set Cd such as 0.44, there's no air entrainment at all. Any inputs?
Old   October 18, 2005, 00:01
Default Re: Thanks.Re: Free surface flow
Bak_Flow
Ken,
this is what I meant earlier about the challenges in modeling the phase interaction terms in such a simplified fashon. ;-)
You can play with the dispersed phase diameter and the drag correlation a bit. However, the physical processes of entrainment, break-up and coalescence, degassing etc will require more details in the model.
Best of Luck,
Bak_Flow
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
Free surface flow settubg boundary conditions and plotting velocity profiles prashanthreddyh FLUENT 2 October 21, 2015 10:58
Meshing for Mutliphase free surface flow MatzeMas ANSYS 2 August 7, 2009 06:06
air bubble is disappear increasing time using vof xujjun CFX 9 June 9, 2009 08:59
free surface flow same as FSI??? Ken CFX 1 February 18, 2008 20:43
