FSI(Fluid Structure Integration) using CFX 10 |
October 13, 2005, 05:09 |
Hi to everybody.Can anayone tell me that can CFx 10 perform FSI or not?second thing is that what should be physiscs for applying acoustic analysis? Thanking you
October 13, 2005, 10:41 |
Re: FSI(Fluid Structure Integration) using CFX 10
Yep, CFX 10 can do FSI. Your options are: 1. Use CEL to define mesh movement based on the Pressure Forces. The Ball Valve tutorial in the documentation uses this approach. 2. One-way coupling to ANSYS, i.e. exporting Pressure data from CFX-Post. 3. Two-way coupling to ANSYS - both solvers run and pass data back and forth.
For detailed acoustic analysis you would have to export the Pressure field to an acoustics package such as LMS Sysnoise. For simple analysis, for example to locate the source of noise, you should just look for transient pressure fluctuations in your results at the frequency of interest. Obviously your simulation has to be transient. A timestep around 1/10 to 1/20 of the highest frequency of interest is required. Mike |
October 14, 2005, 05:37 |
Thanking you for ur guidance.It will help me a lot.
CFX or Fluent for Turbo machinery ? | Far | FLUENT | 3 | May 27, 2011 04:02 |
New ANSYS forum structure, what do you think? | Peter | FLUENT | 10 | February 6, 2009 05:07 |
New ANSYS forum structure, what do you think? | Peter | CFX | 5 | February 4, 2009 12:59 |
Importing solutions in CFX. | Alphonso | CFX | 1 | August 1, 2008 15:01 |
CFX 4.4 installation problem | Pandu Sattvika | CFX | 1 | December 1, 2001 05:07 |
