Negative Pressure
Old   October 6, 2005, 01:48
Default Negative Pressure
S Christopher
I am simulating the entire pump model using CFX. In post processing results, there is a negative pressure around -4 bar (approx.). But Head delivered by the pump is correct.
The Inlet condition are Inlet dynamic pressure and outlet are velocity. Reference pressure is atmospheric. But still there is negative pressure. please give the reason?
If i want to know to exact magnitude of staic or absolute pressure near the blade surface, can i use the same value or some other method is used to find, if so please inform.
Since all pressure are measured from zero absolute pressure.
Old   October 6, 2005, 09:43
Default Re: Negative Pressure
Robin
With incompressible fluids the pressure is always relative. Unless your fluid properties change with pressure or you model cavitation, the reference pressure will have no effect on your solution. It is entirely possible to have very low pressures in this case.
If you were to activate cavitation, I think you would find that your pump is cavitating in the area where the pressure is low. If cavitation is turned on, the reference pressure will have an effect.
Regards, Robin
Old   October 6, 2005, 19:14
I agree with Robin, your pump is probably cavitating in reality. However if your pump simulation without cavitation is accurate then it is likely the cavitation is localised to a small region of the flow, and not having a major effect on the overall flow.
Regards, Glenn
Pressure BC for combustion chamber Giuki FLUENT 1 July 19, 2011 12:35
seeking for help about a room with negative pressure mengyue1 FLUENT 0 November 26, 2009 07:40
High pressure in rhopSonicFoam results in negative pressure shangzung OpenFOAM 0 November 5, 2009 04:24
negative pressure in cfx flar.t CFX 1 December 19, 2006 00:20
negative pressure mAx FLUENT 0 January 25, 2006 15:31
