October 4, 2005, 20:34 |
CFX Piston Motion (CEL)
Can anybody help me to write down a CEL to define a piston motion with moving grid?
October 5, 2005, 14:27 |
Re: CFX Piston Motion (CEL)
How about A/2*(1+sin(omega*t)) Assuming your piston starts at the bottom position and A is equal to the sweep distance. Omega should be the frequency in radians per second (i.e. omeaga=2*pi*f, where f is the frequency).
The mesh distortion will be less if you start the piston in the middle position, in which case you should use A/2*sin(omega*t). Regards, Robin |
October 5, 2005, 19:27 |
Actually Robin, for piston motion mesh deformation with the current model available in CFX5 you have to start the piston at top dead centre. You then define the piston motion relative to the TDC position. If you start anywhere else, when you get to TDC later in the stroke you often get elements turning inside out. Regards, Glenn Horrocks |
May 28, 2012, 05:40 |
#4 | |
Mohammed
May 28, 2012, 07:08 |
Rep Power: 144 |
Your question is just about exactly the example of how not to ask a question on the forum in the FAQ: http://www.cfd-online.com/Wiki/Ansys...ible_answer.3F
CFX arc-modeling, User Fortran, CEL.... | Bloshchitsyn Vladimir | CFX | 2 | October 15, 2007 10:29 |
CFX arc-modeling, User Fortran, CEL.... | Bloshchitsyn Vladimir | CFX | 0 | October 15, 2007 07:39 |
Is linear motion possible to model in CFX? | abe | CFX | 0 | January 10, 2006 01:05 |
Automatic Mesh Motion solver | michele | OpenFOAM Running, Solving & CFD | 10 | September 26, 2005 09:21 |
CFX 4.4 installation problem | Pandu Sattvika | CFX | 1 | December 1, 2001 05:07 |
