Porosity setting in CFX for a specific problem
Old   April 16, 2019, 08:08
Default Porosity setting in CFX for a specific problem
Abdullah Arslan
Goenitz is on a distinguished road
Hi All,
My Qs are:
#1. How can I put interfacial area density with such data
#2. How to compute Resistance loss coefficient Kloss
I am performing heat Transfer analysis on a 2 square channel.
I am trying to derive from the attached file data for CFX porosity tab.
The information I have is volume porosity, permeability, pore diameter, fibre diameter, PPI, inertial loss coefficient (Cf).
Values needed to be input are i)Volume porosity (phi), ii)Velocity type, iii) Permeability (K) and loss coefficient(Kloss), iv)Interracial area density
1. Straight forward
2. Superficial for now as calculation is more realistic
3. Permeability: though value is high but i put as it is. Moreover, it causes no impact on heat transfer and velocity profile even if value is changed 10 order magnitude (decrease or increase).
Loss coefficient is Resistance loss coefficient (Kloss) (1/m) and given in paper is Inertial loss coefficient (no unit). In paper it is given as b=rho*Cf/(sqrtK) of quadratic term. it can be compared to b=Kloss*rho/2 given in CFX theory guide. So Kloss=2*Cf/(sqrtK). Still results are unsatisfactory and I am doubting K value as it is very high K=1.2
4: Formula is 6*(1-phi)/Dp where Dp is particle diameter of foam converted into sphere particle (Dp not pore diameter). For this case any value greater than zero diverging my result from paper but I am using zero for matching results (but in reality there should be at least some value other than zero)
paper link https://www.sciencedirect.com/scienc...60319918314368
Goenitz is offline   Reply With Quote
Old   April 16, 2019, 08:47
Default Adding file
Abdullah Arslan
Pic of my problem.
I have followed nearly everything this page said.
https://www.eureka.im/2409.html
Very good info indeed, BTW
cfx, interfacial area density, porous
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
Simple piston movement in cylinder- fluid models arun1994 CFX 4 July 8, 2016 03:54
Problem with an old Simulation FrankW CFX 3 February 8, 2016 05:28
CFX 4.4 installation problem Pandu Sattvika CFX 1 December 1, 2001 05:07
A problem about setting boundary conditions lyang Main CFD Forum 0 September 19, 1999 19:29
