centrifugal fan
Old   October 3, 2005, 10:19
Default centrifugal fan
Txema
I am starting to simulate a CENTRIFUGAL FAN. 1.I have made the rotor wiht turbogrid 1.6 2.I have made the volute with CFX-Mesh 3.I have put massflow at inlet and pressure at outlet 4.The interface between rotor-volute is a Frozen rotor.
could anyone give me advise?? 1.It is o.k to mesh with CFX-Mesh for volute? 2.How I can know if the mesh for the rotor and volute is o.K. 3.Wich type of interface I must put? 4.How I can model the gap between rotor(rotating) and inlet (static)
Results between experimental data and CFX data are quite diferent.
thank you
Old   November 9, 2005, 08:48
Default Re: centrifugal fan
gogulakrishnan
I want to make a model of a doubble inlet centrifugal fan on cfd can u give guidelines
thanks
Old   November 11, 2005, 07:15
Txema
Star making the impeller with Turbogrid. Massflow at inlet and relaive presure at outlet=0 If you need more acurrate results, put the impeller into de volute.
Modeling of centrifugal fan in CFD Simon Williams Main CFD Forum 3 February 20, 2009 16:00
Multiple reference frame in centrifugal fan Peter Main CFD Forum 0 April 8, 2008 06:37
How to model flow of centrifugal fan? Peter Main CFD Forum 0 April 2, 2008 07:07
boundary condition for centrifugal fan vishal FLUENT 0 November 6, 2007 07:29
centrifugal pump and centrifugal fan Mangesh Main CFD Forum 3 January 3, 2006 12:21
