Cluster run without master node
Old   September 28, 2005, 14:52
Default Cluster run without master node
Mikhail
I have 6 machines and 1 control-oriented computer. Is it possible to start parallel cfx run from master node that is excluded from claster culculation?
Old   September 28, 2005, 19:38
Default Re: Cluster run without master node
No. But you can give the master node a very small partition size so it only has a small computational load. I think you will find this will not be optimum, however. I bet you will find the optimum to be with partitions sized purely on the relative speed of the machines.
Old   September 29, 2005, 00:10
Mikhail
In this case i must have additional license for 7th machines.
Old   September 29, 2005, 09:16
longbow
The new release of CFX provides an "indirect start method" for user to execute a run on remote or batch queuing system. You may find this helpful depending on your cluster configuration. However, considering the size of your cluster, you may just want to login computing node and start job over there. Certainly, this becomes ugly once your cluster has a lot of users and nodes.
Old   September 29, 2005, 09:58
Robin
You can always launch the job on one of the six systems and monitor and control it from the 7th. The Solver Manageronly requires read/write access to the temporary run directory.
For command line options, enter 'cfx5solve -help'.
Regards, Robin
Working directory via command line Luiz CFX 4 March 6, 2011 21:02
Parallel cluster solving with OpenFoam? P2P Cluster? hornig OpenFOAM Programming & Development 8 December 5, 2010 17:06
Full Fluent license required for the master node? Paul FLUENT 1 September 1, 2006 05:26
Running MPI code on a multiprocessor node wen Main CFD Forum 7 April 19, 2006 17:35
Probles with 2 node cluster with Mandrake 10.0 Esti Armendariz Siemens 4 February 1, 2006 12:48
