Import Fluent solution (dat file) as initial solution in CFX |
April 8, 2019, 15:14 |
Ftab
Rep Power: 15 |
Hi all,
It seems that CFD only accepts initial values at .res, .bak, and .trn. Is there anyway to import steady simulation of fluent into CFX to run unsteady? Thanks |
April 8, 2019, 19:38 |
Rep Power: 144 |
The easiest way to do this is to link them together in Workbench. Then workbench takes care of the translation.
April 9, 2019, 10:26 |
Ftab
Rep Power: 15 |
Thanks Glenn!
Will try! I hope I can read the results as initial values this way. |
from fluent, import solution, initial values |
chtMultiRegionSimpleFoam turbulent case | Aditya Patil | OpenFOAM Running, Solving & CFD | 6 | April 24, 2017 23:13 |
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 | keepfit | ParaView | 60 | September 18, 2013 04:23 |
calculation stops after few time steps | sivakumar | OpenFOAM Running, Solving & CFD | 7 | March 17, 2013 07:37 |
pisoFoam with k-epsilon turb blows up - Some questions | Heroic | OpenFOAM Running, Solving & CFD | 26 | December 17, 2012 04:34 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 20:08 |
