Automatic vs automatic with value initialization |
Rep Power: 15 ![]() |
When a transient simulation is initialized by a result file, does it differ to choose automatic or automatic with value if no initial condition other than the result file is specified?
Rep Power: 144 ![]() ![]() ![]() ![]() |
Automatic with value means that if it can get this from the initial results file it will use that value, otherwise it will use the defined value.
If your initial conditions file does not specify a required variable and you have that variable set as automatic then that variable's initial condition will not be specified and the simulation will stop with an error.
If I don’t specify any value under global and domain initialization and choose automatic with value and if a required value does not exist in the result file, will it assume zero?
If I stop a transient simulation which has been already initialized by a result file and then restart it, will I need to uncheck the initialization with initial condition since the run has already been initialized? Which one is correct? uncheck the initialization by initial condition and select current solution data or check the initialization by initial condition and choose the result of the transient simulation as the initial condition and check continue the history |
Can I ask why are you asking this question? A simple experiment by just trying what you ask will answer these questions yourself. Why trust the dodgy memory of somebody you have never met (ie me) when you can figure it out yourself and have no doubt about it?
Gert-Jan
Rep Power: 27 ![]() |
I also suggest to make a backup at zero iteration. Then in Post you can find out yourself what CFX makes of the settings you choose.
FMG initialization query | Mohsin | FLUENT | 6 | November 2, 2016 02:02 |
Full Multigrid Initialization | Mr.Goodcat | FLUENT | 0 | March 17, 2016 06:43 |
CFX temperature initialization | jp_ | CFX | 3 | August 28, 2014 09:06 |
Overflow Error in Multiphase Modelling with Two Continuous Fluids | ashtonJ | CFX | 6 | August 11, 2014 14:32 |
transient simulation of a rotating rectangle | icesniffer | CFX | 1 | August 8, 2009 07:25 |
