April 1, 2019, 05:28 |
simulation of Timisoara Swirl Generator
Zese
Rep Power: 13 |
Dear friends
I want to simulate the flow inside Timisoara Swirl Generator. visiting the Foamwiki, I found ICEM files of the geometry in four separate files (strout,stay vanes, runner, draft tube). I dont know how I can assemble these four mesh as one and do a simulation in CFX. I will be so grateful if any one can help. thanks in advance |
April 1, 2019, 06:09 |
M
Rep Power: 13 |
If the meshes have coincident faces (which I assume they do), you can straight import them to CFX Pre and assemble them there.
Open Pre from the CFX Launcher, start a new case. In the setup tree at the top is a "mesh" branch. Right click there and import mesh. Then you can add them one by one. You must add the mesh regions to your domain and use interfaces to tell CFX which surfaces correspond to one another. |
April 1, 2019, 06:18 |
Rep Power: 144 |
Do the tutorials for the meshing software and CFX and it will show you the general introduction of how to do it. But nobody is going to write a tutorial for you on the forum - https://www.cfd-online.com/Wiki/Ansy...ible_answer.3F
April 1, 2019, 10:24 |
#4 | |
Zese
Rep Power: 13 |
restarting paused transient simulation using reactingFoam | JMDag2004 | OpenFOAM Running, Solving & CFD | 1 | August 10, 2015 11:15 |
Swirl Flow simulation in a burner | Raman_Chawla | Main CFD Forum | 0 | June 10, 2015 06:37 |
Use homogeneous results as the initial guess for an inhomogeneous simulation | JuPa | CFX | 5 | December 26, 2014 14:44 |
High Frequency Residual Oscillation in Axisymmetric with Swirl Simulation | newbie384 | FLUENT | 0 | July 8, 2013 09:25 |
3-D Contaminant Dispersal Simulation | Apple L S Chan | Main CFD Forum | 1 | December 23, 1998 11:06 |
