March 30, 2019, 20:48 |
Nusselt Number on surface
Marcin
Rep Power: 9 |
Hi everyone
I exported necessary data from CFX to calculate local values of Nusselt number in excell. Now i got coordinates (x,y,z) and Nusselt number associated with it, is it possible to display it somehow in result. In attachment you can see coordinates and local Nusselt number. Thanks for any suggestions. |
March 31, 2019, 00:22 |
Rep Power: 144 |
It would be better if you put the Nusselt Number equation into CFD-Post so it becomes a CFD-Post variable. Then it can be plotted like any other CFD-Post variable.
March 31, 2019, 05:32 |
Marcin
Rep Power: 9 |
Yes, that’s right but using cfx function i can’t calculate nusselt number locally, because i need to use area average od area integrated heat flux , that result in average Nusselt number calculation, is it possible to calculate it for example in every mesh element?
March 31, 2019, 06:01 |
Rep Power: 144 |
CFX has area average and area integral functions in CEL.
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 09:54 |
simpleFoam parallel | AndrewMortimer | OpenFOAM Running, Solving & CFD | 12 | August 7, 2015 19:45 |
SigFpe when running ANY application in parallel | Pj. | OpenFOAM Running, Solving & CFD | 3 | April 23, 2015 15:53 |
Nusselt number variation over a ribbed surface | avi031 | FLUENT | 2 | March 10, 2011 13:09 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 13, 2001 00:19 |
