Total Temperature in a Rotating Frame
Old   September 10, 2005, 12:37
Default Total Temperature in a Rotating Frame
Paul Lewis
Hi Everyone,
I've noticed in the rotating frame of my simulation the total temperature in some places is less than the temperature at the same point. I would expect the solver to calculate To = T + V^2 / 2Cp, and therefore To > T (total temp greater than static temp).
The problem doesn't occur in the stationary frame of my simulation, has anyone seen anything similar before? I'm using CFX 5.7
Regards
Paul
Old   September 14, 2005, 15:47
Default Re: Total Temperature in a Rotating Frame
Neale
"Total Temperature" is based on Rothalpy. Your formula is not correct. It should be To = T + 0.5*(V_rel^2-V_spin^2)/Cp. This can be less than static Temperature if V_spin is large. See the documentation on "Rotating Frame Quantities" in the Solver Theory Manual for more info.
Problem with zeroGradient wall BC for temperature - Total temperature loss cboss OpenFOAM 12 October 1, 2018 07:36
Rotating rotor inside a frame wllmk1 OpenFOAM 38 April 8, 2014 07:58
Tf is averaged by static or total temperature ?? NPU_conanxie Main CFD Forum 0 April 6, 2011 22:30
What is the relation between Static temperature And total temperature? subhankar_bhandari FLUENT 1 August 18, 2010 15:46
N-S equations in rotating frame Li Yang Main CFD Forum 11 September 28, 2002 10:25
