Imported user surfaces in CFD-Post
Old   March 22, 2019, 12:39
Default Imported user surfaces in CFD-Post
HS
amsys is on a distinguished road
Dear all,
I exported a calculated variable from CFD-Post (Wall Shear where the location is the wall of an artery) in order to calculate a new variable in matlab. I then imported via the user defined surface, the new variable in a .csv file with of course the wall info (connectivity, face, X,Y,Z). However, the variable is only associated with the imported user surface and not a CFD domain so I can’t use the user surface as a location when I'm creating a polyline for instance. Any suggestions on how I can overcome this?
Thanks!
amsys is offline   Reply With Quote
Old   March 22, 2019, 17:56
Gert-Jan
Gert-Jan will become famous soon enough
Please explain what you re trying to do. What is your goal and how are you going to achieve this?
Gert-Jan is offline   Reply With Quote
Old   March 23, 2019, 07:16
HS
I want to export the selected variable "CFL on user surface" at Location "Polyline" but I get this error:
"The following variables are not present in the geometry and will be omitted from the exported data: CFL on user surface"
cfd-post, user surface
Guide: Getting Started with the CFD Online Discussion Forums pete Site Help, Feedback & Discussions 8 July 29, 2016 06:00
Post processing in CFD Post or Fluent. Blobs OpenFOAM Post-Processing 2 June 26, 2016 08:23
Problem regarding producing streamlines from surfaces in Ansys CFD post gauthamnarayan ANSYS 6 June 8, 2015 08:33
Problem regarding producing streamlines from surfaces in Ansys CFD post gauthamnarayan Visualization & Post-Processing 0 April 23, 2015 17:07
Poly lines in CFD Post ashtonJ CFX 0 December 2, 2010 03:46
