March 18, 2019, 13:47 |
Mesh stiffness when using mesh deformation
#1 | |
Lonja Selter
Modeling a hydraulic motor with moving pistons. I am unsure of how mesh stiffness works with regard to mesh deformation. Below is an image of what I am getting, when I am expecting an even stretch/compression of elements along the piston bore. deformation is given in X and y components relative to initial position and is multiplied by an interpolation function to interpolate between 1 at the piston face and 0 towards the piston top (2). I have tried increasing stiffness near small volumes and a value as below (1). So my question is: as I have defined the movement of each node relative to its initial position, including interpolating between maximum movement and no movement, can I disable the mesh stiffness or change it to have no noticeable effect. movement defined as below: P1MMX and P1MMY are the final movement equations. Quote:
March 18, 2019, 17:43 |
Rep Power: 33 |
You cannot disable mesh stiffness since it is a required parameter of the model.
However, you can make its influence disappear by using a uniform value throughout the domain, say 1 |
March 18, 2019, 18:19 |
Rep Power: 144 |
I have modelled a lot of piston compression things and I can tell you that the CFX mesh motion stuff works well if you start the mesh at top-dead-centre and expand it to bottom-dead-centre. If you try the other way around the mesh always ties itself in knots.
mesh deformation, stiffness |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 08:38 |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 06:38 |
Gambit problems | Althea | FLUENT | 22 | January 4, 2017 04:19 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 10:38 |
CFX Mesh Deformation problem | Silmaril | CFX | 7 | October 19, 2010 11:00 |
