Confusion choosing between static / transient simulations |
March 15, 2019, 10:27 |
Tharun Suresh
Rep Power: 7 |
I have a machine tool in a flow environment with constant boundary conditions (inlet velocity, outlet pressure etc.). The soultions of this simulation serves as the boundary data for thermo-elastic simulations inorder to find thermal deformation. However, the experiments results have time of 2 days and I have to give simulations time accordingly for thermo elastic simulations. My question is, which type of simulation (steady/ transient ) is more suited in CFD for this problem. For importing boundary convection data for each time step, I believe I should perform transient CFD simulations. But the Heat transfer coefficient values are independent of time and this creates the confusion whether I shoud stick with static CFD simulations. I seek some advice on this.
Thanks! |
March 15, 2019, 18:53 |
Rep Power: 144 |
It is common when you are dealing with multiple physics that they are on very different time scales. But the way to handle it depends on what you are doing - sometimes you can use a steady state approach, sometimes you need the full transient.
So you would have to explain what you are doing for us to suggest the best way forward. Some images would help.
cfd, thermoelastic |
Convergence in steady state simulations vs transient ones | cardioCFD | CFX | 5 | January 21, 2018 11:59 |
error: uninitialized local variable 't' used | MASOUD | Fluent UDF and Scheme Programming | 5 | October 17, 2016 05:24 |
Read inside a class | tonyuprm | OpenFOAM | 12 | July 14, 2010 03:35 |
How are a transient simulations performed?? | Luk | Main CFD Forum | 0 | October 19, 2007 11:09 |
URANS and Transient Simulations | bob | Main CFD Forum | 0 | October 1, 2003 04:54 |
