Drag Coefficients
Old   August 31, 2005, 09:42
Default Drag Coefficients
Meri
Hello All, My questions are in 2 parts: 1) I have been working on external flow over bluff bodies with CFX for a while, I am able to obtain good values on lift and Moments very close to Wind Tunnel Results, however Drag has proved stubbornely difficult, at higher angle of incidence, say 5 deg or more it improves remarkably, I wonder if any one has experience to share with me that may be helpful. I am using the SST with Sp. Blend factor. 2) My other question is if anyone has or know of numerical or experimental work or depository on airfoils or other bluff bodies showing the ratio of viscous force to pressure force as regards lift,drag and moment. Cheers !
Old   September 1, 2005, 04:58
Default Re: Drag Coefficients
DAK565656
Go to main forum and find this topic: "High values of Cdrag".
Old   September 24, 2005, 10:57
victorzcc
I am doing the same work with you, I want a deep communion with you!
lift and drag coefficients around a ground vehicle Pedro CFX 3 September 5, 2012 19:31
Incorrect Drag Coefficients w-nicholson ANSYS 2 July 8, 2011 13:31
Incorrect Drag Coefficients / Mesh Confirmation w-nicholson ANSYS 3 May 18, 2011 13:00
Final Year Project - CFD on Drag coefficients jamesho123 Main CFD Forum 1 September 15, 2009 22:50
Lift and Drag Coefficients Reliability Luis FLUENT 2 December 27, 2005 15:45
