Initialize transient simulation with steady state result file with pbs script
Old   March 7, 2019, 23:11
Question Initialize transient simulation with steady state result file with pbs script
Tingting Wu
Tingting Wu is on a distinguished road
Hi all,
I'm trying to do transient simulations on a cluster with pbs script. But I don't know how to use the steady state results file to initialize the flow field.
The pbs script I used is: "$CFX_BIN -def $JOB_INPUT -ini-file $INITIALFILE -double -par-dist $nodes -start-method "Platform MPI Distributed Parallel"
The INITIALFILE=46005_001.res
But an error occurred: " Unknown command line 46005_001.res"
Tingting Wu is offline   Reply With Quote
Old   March 8, 2019, 07:09
Gert-Jan
Gert-Jan will become famous soon enough
isn't it just -ini instead of -ini-file
Gert-Jan is offline   Reply With Quote
Old   March 8, 2019, 08:54
Opaque will become famous soon enough
Something is wrong with the passing of variables in the script
Try swapping the order in the command line to see which error do you get, say
$CFX_BIN -ini-file $INITIALFILE -double -def $JOB_INPUT -par-dist $nodes -start-method "Platform MPI Distributed Parallel
Opaque is offline   Reply With Quote
Old   March 11, 2019, 06:57
Tingting Wu
I've tried them both. But it worked out magically in the end without changing anything in the script. Thanks anyway!
linux, pbs, transient simulation
[Other] Tabulated thermophysicalProperties library chriss85 OpenFOAM Community Contributions 62 October 2, 2022 04:50
[swak4Foam] Installation Problem with OF 6 version Aurel OpenFOAM Community Contributions 14 November 18, 2020 17:18
[OpenFOAM.org] Error creating ParaView-4.1.0 OpenFOAM 2.3.0 tlcoons OpenFOAM Installation 13 April 20, 2016 18:34
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 17:02
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
