Two phase (water-air) in centrifugal impeller
Old   March 4, 2019, 05:20
Default Two phase (water-air) in centrifugal impeller
Mentzos
phPatras is on a distinguished road
My problem is that when I change my flow condition from water (where the solution is ok) to water-air the pressure at inlet become bigger than at outlet...?
phPatras is offline   Reply With Quote
Old   March 4, 2019, 23:21
Svetlana Tkachenko
Svetlana is on a distinguished road
Could you describe the problem a bit more please? Include a picture of the velocity vectors or pressure contours or both and then someone can give you a tip or try running a similar problem for a quick test.
Svetlana is offline   Reply With Quote
Old   March 7, 2019, 04:34
Mentzos
My mistake ... at the boundary condition.My domain is a section of an impeller (as periodically repeated). At the case of water i use the "turbo" function and the mass flow that i put concern all the impeller. At two phase this function don't work... and so i have to change the mass flow.
compressibleInterFoam case – a flat wall air cavity filling up with water Zeppo OpenFOAM Running, Solving & CFD 0 October 3, 2015 11:01
Can people model 2 phase fluid flow (air water) in 6 mm tubing? gaiatechnician Main CFD Forum 0 August 25, 2015 15:20
Please**need help on Tow phase flow ( water & steam water) analysis** ali_kntu CFX 2 December 19, 2013 17:15
I am NOT getting right pressure at the air inlet in water column kcfd FLUENT 2 November 27, 2012 22:36
I am NOT getting right pressure at the air inlet in water column kcfd FLUENT 0 November 25, 2012 00:14
