Cfx rotating domain
Old   March 3, 2019, 08:21
Default Cfx rotating domain
Giorgi
Gvasalli is on a distinguished road
Hello everyone
I had a problem while setting timestep for rotating rotor at 100000 rev/min which takes 0.0006 seconds to complete one revolution when I was setting time step less than 0.0006s and saving each timestep as a result file in cfx post rotor wasn't rotating now when I set timestep 0.0002s and save every 3 trn files rotor is rotating in cfx post. Could you tell me why?
Best regards
Giorgi
Gvasalli is offline   Reply With Quote
Old   March 4, 2019, 06:24
M
AtoHM is on a distinguished road
There is an option in post to transform the mesh according the rotation I think. It might be set up differently for .trn and full results by default, causing it to rotate or not rotate depending on the ouput type.
AtoHM is offline   Reply With Quote
Old   March 4, 2019, 06:29
Giorgi
Thank you. I will try.
Best regards
Old   March 5, 2019, 02:06
urosgrivc
urosgrivc is on a distinguished road
If you only have one rotating domain this one will not appear to rotate in post, It will only rotate if you have at least two domains connected with a transient rotor-stator connection, This said I think that something can surely be done, as you can do almost anything in post.
urosgrivc is offline   Reply With Quote
Old   March 5, 2019, 02:20
Giorgi
I have this type of connection and domain is rotating but at some specific timesteps it appears to be fixed
Rotating or stationary domain in pump/turbine cavity Christian Høy CFX 3 March 17, 2017 07:03
convergenceof natural convection prob. in cfx cpkewat CFX 15 January 31, 2014 07:29
Rotating Domain Szczepan CFX 8 January 19, 2013 10:27
Different conductivities for a SINGLE domain for CHT problem in CFX Mehul CFX 3 August 3, 2012 10:01
question about governing equation in CFX using rotating/non rotating reference frame rystokes CFX 0 January 12, 2010 07:14
