August 19, 2005, 12:08 |
Tangential velocity
Need some help on swirling flow through an elbow diffuser. I wanted to plot and export the tangential velocity at a plane. I am using CFX-5.7.1. I have tried two methods which have both be taken from the CFX community site. 1)writing an expression tanVel = (-Velocity u*y+Velocity v*x)/max(sqrt(x^2+y^2),1e-8[m]) 2)As Robin had mentioned, "use the Turbo menu and select "Modify Rotation Axis" and specify your rotation axis. Post will then calculate cylindrical coordinates and velocity components about this axis." Both the methods give me the same contour plots, but it doesnot match with velcoity vectors plots projected tangentially on the same plane. Areas of high swirl that are visble on the vectors plots donot match with that of the contour plots. Can someone tell me how to plot the tangential velcoity or why this problem arises, how importatnt is the CSYS in this regard? Regards, Santhosh |
August 20, 2005, 07:53 |
Re: Tangential velocity
Sorry, mistake was at my end, the orgin in the CAD model was at the wrong place, hence it kept giving wrong values.
Santhosh |
UDF error - parabolic velocity profile - 3D turbine | Zaqie | Fluent UDF and Scheme Programming | 9 | June 25, 2016 20:08 |
how to compute relative velocity from absolute? | spk | Main CFD Forum | 3 | July 9, 2010 09:42 |
Cyclone Tangential Velocity ... | Abdul | FLUENT | 2 | August 13, 2008 01:07 |
Neumann pressure BC and velocity field | Antech | Main CFD Forum | 0 | April 25, 2006 03:15 |
Radial and tangential velocity | Antonio Mileo | FLUENT | 2 | February 16, 2001 02:41 |
