Changing from Upwind Scheme to High Resolution Scheme |
March 1, 2019, 11:43 |
Andre
I am currently running time-consuming simulation using CFX through Workbench. I am trying to streamline the process between running initial upwind scheme to get an approximate solution then switching to high resolution scheme without user interference overnight/weekend. I have looked online and can't find a solution other than manually doing so. Has anyone found a solution for this?
March 1, 2019, 13:45 |
Gert-Jan
Rep Power: 28 |
You can do this outside Workbench, running CFX as standalone package using a batch file.
March 1, 2019, 14:38 |
Rep Power: 33 |
You can setup a "multi-configuration" simulation
First Analysis with Upwind Duplicate the First Analysis, Rename as you wish, say Second Analysis Change Upwind to High Resolution in the second analysis Second simulation with High Resolution, starting once the first is over Save definition file, open Solver Manager, start the run. Once finished, you can see both simulations. |
March 1, 2019, 16:51 |
Andre
Is it possible to set the initial solution of the high resolution scheme as the solution of the upwind scheme automatically?
March 1, 2019, 17:40 |
Rep Power: 33 |
Yes!!
For each analysis, you define the run parameters. That means, you set the second analysis to use the initial values file as the results file of the first analysis. |
automating, high resolution, upwind |
Upwind Scheme | Juzzvy | OpenFOAM Running, Solving & CFD | 0 | October 17, 2018 05:34 |
[PyFoam] Problems with the new PyFoam release | zfaraday | OpenFOAM Community Contributions | 13 | December 9, 2014 18:58 |
[PyFoam] having problems with pyfoam Installation | vitorspadetoventurin | OpenFOAM Community Contributions | 3 | December 2, 2014 07:18 |
High resolution image with parafoam | Andrea_85 | OpenFOAM | 5 | January 23, 2014 06:39 |
Drag comparison upwind vs. scheme | Luk_Fiz | CFX | 3 | April 27, 2009 21:42 |
