Loading the geometry in Ansys Meshing is so Time-Consuming |
February 24, 2019, 00:42 |
Sasan Ghomi
Rep Power: 15 |
Dear all,
I am dealing with a geometry which includes a huge number of bodies. It is more than 2 days that I am waiting for Ansys Meshing to open the geometry. My question is that how I can speed up this process. Does share topology can open any doors here? Any ideas? Best Regards |
February 24, 2019, 05:36 |
Rep Power: 144 |
Wow, you are very patient. Are you using the latest version of ANSYS (2019R1)? If you are using the latest version then it could be worthwhile reporting this as a feature request/bug report. If you are using an older version then don't bother, upgrade to the current version and try again.
I am not not sure what could be done to speed this up. Certainly try the things you suggest. Also, I do all my complex and large meshing in ICEM as it handles complex stuff much better than ANSYS Mesh. So ICEM could be another thing to try - but be aware that ICEM is very different and will require some effort to learn.
[ANSYS Meshing] Ansys meshing does not respond when it is opened after the first time | MikhO | ANSYS Meshing & Geometry | 0 | February 16, 2018 09:08 |
pressure in incompressible solvers e.g. simpleFoam | chrizzl | OpenFOAM Running, Solving & CFD | 13 | March 28, 2017 06:49 |
Floating point exception error | lpz_michele | OpenFOAM Running, Solving & CFD | 53 | October 19, 2015 03:50 |
Star cd es-ice solver error | ernarasimman | STAR-CD | 2 | September 12, 2014 01:01 |
mixerVesselAMI2D's mass is not balancing | sharonyue | OpenFOAM Running, Solving & CFD | 6 | June 10, 2013 10:34 |
