March 21, 2019, 05:15 |
#41 | ||||
Rep Power: 144 |
So the problem is not your time step settings, but the rest of your simulation. the first thing to do is to improve mesh quality, that always helps. You can also do a time step and convergence criteria sensitivity study to see if you can loosen then at all. But overall, this is how CFD works. When you try to do accurate simulations the simulation get very big with long run times. That is why a good deal of the world's supercomputers are built to do CFD simulations. CFD was never meant for cheap desktop computers.
March 27, 2019, 09:30 |
#42 | |
Rep Power: 15 |
I am using SST turbulence model and I have kept y+ under 1 which has made the mesh very fine. If I use k-e model which needs a y+ more than 11 and does not need a fine mesh, will the solution be inaccurate in terms of mass flow/pressure ratio prediction? Right now, the adaptive time step is using 2.6e-6. When it uses such a fine time step, will anything coarser than that certainly yield inaccurate result? |
March 27, 2019, 16:38 |
#43 |
Rep Power: 144 |
Anyway which affects convergence will affect the time step determined by adaptive time stepping. This is just about everything
Will a k-e simulation with y+>11 be inaccurate? That depends on your situation. k-e is a very good model in many cases, that is why it is the default turbulence model in many other CFD codes. Also, do not assume that you must have y+<1 when you use the SST model. This is a common furphy. SST can handle coarser meshes than that in many cases. No matter what turbulence model you use, you should determine the wall resolution by sensitivity analysis. If you use a coarser time step then you won't be converging every time step. If you don't converge the time steps then your time history will be wrong.
March 28, 2019, 15:15 |
#44 | |
Rep Power: 15 |
Do other transformation methods such as TT or FT have better convergence rate compared to the PT? |
March 28, 2019, 17:42 |
#45 |
Rep Power: 144 |
There is no general upper limit to y+. If your flow is not much affected by the boundary layer you can make it what ever you like and it will be fine. So just do a sensitivity study and see how sensitive you are to it.
I do not understand your second question. Please do not use acronyms, especially ones which are not in common usage. I do not know what your acronyms mean.
March 29, 2019, 02:40 |
#46 | ||
Rep Power: 15 |
Does it have significant effect on global parametrs such as mass flow or stage pressure ratio? Quote:
PT: Profile Transformation TT: Time Transformation FT: Fourier Transformation |
March 29, 2019, 04:33 |
#47 | |
Rep Power: 144 |
Wind tunnel Boundary Conditions in Fluent | metmet | FLUENT | 6 | October 30, 2019 13:23 |
Domain Reference Pressure and mass flow inlet boundary | AdidaKK | CFX | 75 | August 20, 2018 06:37 |
reference pressure and compressible flow | bingo10 | CFX | 0 | September 11, 2013 08:32 |
OpenFOAM 1.6 ext - Compilation errors - Fedora 17(32bit) | toolpost | OpenFOAM Installation | 15 | September 21, 2012 10:38 |
about reference pressure | adam2008 | CFX | 1 | May 17, 2011 09:03 |
