Do I need a wider box?
Like Tree4Likes
Old   February 22, 2019, 19:25
Default Do I need a wider box?
tyw7's Avatar
Thu Win
tyw7 is on a distinguished road
Attached is the pressure plot of the farthest wall. Do I need a bigger box?
I am calculating the lift on a wing and not quite sure if a bigger box is needed. I am already 3x the wingspan
tyw7 is offline   Reply With Quote
Old   February 23, 2019, 04:27
While a bigger box will help (it always helps), I suspect correcting your boundary conditions is the more fundamental problem. Are your top and bottom faces walls or symmetry? You should either make it a translational periodic pair or make it part of the inlet.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Old   February 23, 2019, 07:02
tyw7's Avatar
Thu Win
All 4 faces are set as symmetric. Is that wrong?
Picture shows the furthest most side wall.
Old   February 23, 2019, 18:28
What 4 faces are symmetric? What are the other faces? The picture shows the side wall furthest from what?
Please explain what you are doing.
Old   February 23, 2019, 18:32
tyw7's Avatar
Thu Win
See attachment. The unshaded are all symmetric.
It's a half wing attached to the wall right most wall.
Old   February 24, 2019, 05:38
Your diagram is not very clear but hopefully I can guess what you mean.
I think my post #2 is talking about the correct issue, refer to that.
Old   February 24, 2019, 07:27
tyw7's Avatar
Thu Win
I'm not quite sure what you meant as part of the inlet? Should the top and bottom, let's call this the roof and floor, to be inlets?
Old   February 24, 2019, 18:28
Assuming your inlet is defined as a velocity with a magnitude and direction defined, and your outlet is an outlet or opening with 0 relative pressure, and domain is a box and your flow is from left to right:
Then a good way to define this is to have the right face as your outlet and all other faces (left, top, bottom, front, back) set as inlet.
This allows you to change the angle of attack in the inlet and not see the effects you show in your first post.
aero_head likes this.
Old   February 24, 2019, 18:29
tyw7's Avatar
Thu Win
So no walls?
Old   February 25, 2019, 00:24
That's right. The 6 sided box has 5 sides as inlets and 1 side an outlet.
Old   February 25, 2019, 04:17
tyw7's Avatar
Thu Win
What's the advantage of this vs the traditional 4 wall approach?
Old   February 25, 2019, 05:46
I don't think you could call the "4 wall approach" traditional as it is not recommended in most cases
You can't model varying angles of attack with a single mesh in the approach you are using, but my suggestion allows it. That sounds like a pretty clear advantage to me.
Old   February 25, 2019, 05:49
urosgrivc
urosgrivc is on a distinguished road
What makes you think that a 4 wall approach is more traditional.
Usually, a physical test in the wind tunnel has 4 walls, as it is not possible to make a physical tunnel without any walls.
And this is bad actually, imagine an aeroplane flying through the air, are there really 4 walls there ??
This is, or can be, an advantage of CFD ower physical wind tunnels actually as in a lot of cases we do not want the influence of the walls on our results.
It depends of course if this is appropriate for your case or not:
If you are doing a direct comparison of CFD versus wind tunnel tests, then I would include the walls, to make the simulation as close to real measurements as possible.
But if you want true data of let us say drag coefficient of a plane flying in the air than you have the ability in numerical simulation to actually do it better and not have the influence of the walls.
urosgrivc is offline   Reply With Quote
tyw7's Avatar
Thu Win
How would varying angle of attack work? And got any tutorial for the 4 inlet approach?
Old   February 25, 2019, 06:00
urosgrivc
It is simple
At the inlet, you can select in which direction the flow is going
If the flow is only in let us say X direction than the angle of attack is 0°
but if you have velocity in X and Y direction than this inlet velocity angle is the new angle of attack vhich is not 0° anymore.
And you have to account for this change for the force of drag and lift evaluation, of course,
it is best to make expressions with sin or cos functions to do all the work for you,
So you only bother with degrees of rotation.
And your domain shape can be optimised for this (because of the sharp angles and interfering inlets), This is why you are able to see CFD simulation of wings in Elliptical domains also
Old   February 25, 2019, 06:02
tyw7's Avatar
Thu Win
Ah gotcha. And I'm assuming they're coupled together ie all considered 1 inlet?
Like in the boundary conditions, you model the 4 sides as a single inlet rather than separate inlets?
Old   February 25, 2019, 06:33
urosgrivc
Yes these can be considered as one inlet
There is an even simpler method for Angle control though
I actually like this one better, far less work and no cos, sin functions..
Here it is:
You can Transform the mesh in the CFXpre,
If you add rotation, this can rotate the mesh of the whole domain by some degree
So you can have a fixed inlet velocity vX and forces and all will be according to the initial coordinate system
Old   February 25, 2019, 11:37
tyw7's Avatar
Thu Win
PS do you have any reference regarding the 5 walls?
This is for a university project and every decision should be backed up.
Old   February 25, 2019, 19:31
Have a look in the literature. Most far field simulations are done this way. The "C-grid" approach is a common one which is similar but uses a structured mesh.
Old   February 25, 2019, 19:32
tyw7's Avatar
Thu Win
What's the name of the approach? I had a Google and couldn't find anything relevant.
PS I tried that method and got some weird pressure stripings.
File Type: jpg Screenshot 2019-02-25 at 11.34.51 PM.jpg (76.4 KB, 7 views)
Getting started with CyclicAMI Algebraist OpenFOAM 4 February 11, 2019 02:39
Initial values and boundary condition for LES simulation of a box SaddamH OpenFOAM Running, Solving & CFD 1 July 31, 2018 03:21
I get different results when I scale the 'falling box' tutorial Hossein1 FLUENT 7 August 19, 2017 03:52
[DesignModeler] simply model, empty box conquer ANSYS Meshing & Geometry 0 March 28, 2014 19:26
Immersol Simulation of a Heated Box Dong Phoenics 0 March 2, 2006 22:20
