Do I need a wider box?
Like Tree4Likes
Old   February 26, 2019, 01:58
urosgrivc
urosgrivc is on a distinguished road
Your streamlines look bent. Why is that?
Do you have the option of normal inlet flow direction activated??
You should specify the direction.
If this is maybe the problem
urosgrivc is offline   Reply With Quote
Old   February 26, 2019, 02:16
Please post your CCL and an image of your setup, including which faces you have applied boundary conditions to.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Old   February 26, 2019, 05:14
tyw7's Avatar
Thu Win
tyw7 is on a distinguished road
What's ccl?
tyw7 is offline   Reply With Quote
Old   February 26, 2019, 17:36
CFX command language. This is the text on the top of the output file which describes the setup of the run. For further details look in the CFX documentation.
Old   February 26, 2019, 17:40
tyw7's Avatar
Thu Win
Here you go. Had to zip the ccl cause the forum did not recognize it.
Old   February 26, 2019, 22:59
Do you know what "Normal Speed" means for your boundary condition? You obviously cannot use that option if you are making the 5 faces inlets. Have a look at the other options for inlets and see if something else is more appropriate.
Are you intending running different angles of attack for this model, or just the angle of attack in your solid model?
Old   February 26, 2019, 23:04
tyw7's Avatar
Thu Win
For that particular model, no. But for a similiar model, yes. I had a look at the Cartesian uvw coordinate but I'm not quite sure how it'd work. Am I correct to assume that if I put everything as 0 and the velocity at the v axis, it'd be similiar to the wind blowing from the front?
I'm assuming normal mean the wind is blowing normal to the surface? So from the top it'll be straight down?
Old   February 26, 2019, 23:49
Yes, that is right
Old   February 27, 2019, 02:03
urosgrivc
And check if you need to do some changes to the model, like using the air ideal gas and total energy model to account for compression or some other settings because of the really high velocity you have 250m/s (and will probably be higher locally near the wing) is transonic and some weird stuff begins to happen.
Maybe Glenn knows more about this, as I haven't done any research for transonic and supersonic flows yet, but I have heard that it is not the same as for flows slower than Mach 0.3.
compresible flow
https://www.sharcnet.ca/Software/Ans.../i1298574.html
Old   February 27, 2019, 06:20
tyw7's Avatar
Thu Win
How can I know if I need to account for compressibility?
Old   February 27, 2019, 06:37
The rule of thumb for aircraft flows is that over Mach 0.3 you need to account for compressibility.
aero_head likes this.
Getting started with CyclicAMI Algebraist OpenFOAM 4 February 11, 2019 02:39
Initial values and boundary condition for LES simulation of a box SaddamH OpenFOAM Running, Solving & CFD 1 July 31, 2018 03:21
I get different results when I scale the 'falling box' tutorial Hossein1 FLUENT 7 August 19, 2017 03:52
[DesignModeler] simply model, empty box conquer ANSYS Meshing & Geometry 0 March 28, 2014 19:26
Immersol Simulation of a Heated Box Dong Phoenics 0 March 2, 2006 22:20
